for the sake of people using this faq as a bible, if i remember this stuff correctly... you only need to swap the 'fatter' ac lines (2), i forget if they are the high or low pressure....the others can be bent to fit as long as you don't crimp them. and na's need a tt vacuume res. that goes to the fuel dampner and an extra solenoid, which is the same as the egr solenoid. the na cold air intake metal pipes (the ones off the rubber Y) are different...actually they are similar, but the place where the recircs plug in is larger on na's.
